6.1/7.1 - really worth it
Discussion in 'Home Cinema Speakers' started by bonehead, Jun 18, 2004.
  1. bonehead
    bonehead
    I'm considering upgrading a few bits of kit, including changing my amp to one capable of 6.1 and 7.1 output.
    In a small room (3m width x 4.5m length) how much am I going to gain with the 1 or 2 extra speakers? If I do go for the extra I'm leaning towards 6.1 rather than 7.1.
    Any advice?
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,185
    2
    2
    137
    Airdrie, Scotland
    +1,006
    I have just recently upgraded from 5.1 to 6.1 (using the Kef 2005.2 "eggs") and must say I am delighted with the difference. For your information, my room is 6 x 4 metres, and my amp is a Denon 2802.
    Hope this helps.
    Cheers,
    Martin.
  3. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    i have a 4x 4.5m room and overall, i'd say i wish i hadn't bothered with 6.1. just seemed a waste of having a 7.1 capable amp and not using the extended surround capability. for a smaller room, definetly keep with 5.1
    incidentally, if u still want to go to 6/7.1, i hope your new amp has DPLIIx. That gives a true 6/7.1 signal from 2ch sources. If it hasnt', then get one!! the Yamaha RXV450 supports it.
