5V Power supply hard wiring
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by WAYNEDOLLEY, Feb 9, 2009.
  1. WAYNEDOLLEY
    WAYNEDOLLEY
    Apr 23, 2006
    1,797
    +35
    Can anyone give me there advice on how it is best to hard wire your sat nav into your vehicle. I have a Saab 93.
    But the basics will be the same.
    I do not want to run power from the cigar lighter as the cable trail through the car and I have to have the ashtray open for access to the lighter.
    This looks naff.
    I want it to appear as a professional installation.
    Cheers.
    Wayne.
  2. Rodders53
    Rodders53
    Dec 8, 2007
    5,219
    Bedford
    +947
    Almost all sat nav's will us a cigarette-lighter'-style plug in module to supply the correct voltage, current and polarity to the connector for the unit.
    Therefore you'll need to find a suitable location in the dash or glovebox or other area behind some trim where that plug unit plus a wired socket (similar to some of thse shown on 12 Volt Plugs & Adaptors from Towsure ) can be located.
    The input wires to that socket will need to pick up a suitable +12v fused feed (ignition controlled, or manually switched from somewhere) and a ground/earth (via a screw into the bodywork). A Saab owners forum may have someone who can advise where to get the power feed from.
    You'd be wise to tie-wrap the plug and socket together to ensure they stay mated properly if they are inaccessible.
