5M DVI to VGA Cable
Discussion in 'Cables & Switches' started by oblivion_6, Mar 26, 2006.
  1. oblivion_6
    oblivion_6
    Mar 17, 2006
    140
    Glasgow
    +3
    Guys im wanting to send the output from my pc to my lcd telly via the vga port so i need to get a cable to send the dvi feed there
    ANyone on the forums make these or able to recommend a good one? ideally not wanting to spend more than about 30 quid
    cheers
    I have read and agreed to abide by the AV Forums trading rules : Yes
  2. shyewei
    shyewei
    Dec 11, 2002
    5,610
    London
    +208
    This is probably better of in the cables or wanted section.
    Maplins does a Banbridge DVI -> VGA cable for £19.99 for a 2m. I was looking for one of these too. Not very common, adaptors seem more readily available.
    Shye
  3. Roo
    Roo
    Sep 30, 2004
    100
    Cornwall
  4. Smak
    Smak
    Dec 27, 2005
    979
    46
    Leicester
    +212
    Im looking at linking my PC to the VGA input on my LCD TV, my PC has dual DVI outputs (Nvidia 6800U), would it not be better to use a DVI - DVI cable then use a VGA convertor at the TV end? Instead of using a VGA - VGA cable with a DVI convertor at the PC end? I thought maybe the DVI cable would better as the signal will be digital up to the TV, although I could be completely wrong :confused:
    EDIT: Just found this cable, sounds ideal, what do you reckon?
    http://www.futureshop.co.uk/profigold-pgm1205-dvia-to-vga-cable-5m-p-480.html
  5. oblivion_6
    oblivion_6
    Mar 17, 2006
    140
    Glasgow
    +3
    That looks the business actually ill just order that :)
    ta m8
    thanks everyone for your posts
  6. Smak
    Smak
    Dec 27, 2005
    979
    46
    Leicester
    +212
    I wanted the 10m one but it's out of stock :mad:
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,744
    The Borders
    +3,516
    Hello all
    I take it everyone is assuming oblivion 6 has a DVI-I Output on the PC - if its a DVI-D Output you'll require something far smarter (and costlier) than an adapter cable or dongle.
    Best regards
    Joe
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,744
    The Borders
    +3,516
    Hello Smak
    As per my previous post - you have to be aware of the different DVI socket types and what signals they output.
    Some kit use DVI-I sockets - these allow you to Output a Digital or Analogue signal from the Source.
    Some kit use DVI-D sockets - these only allow you to Output a Digital signal from the Source.
    If you have a Monitor with a VGA input and a Source with a DVI-I Output you can set the Source to Analogue, set the resolution to match your Monitor resolution and then use a DVI-I to VGA cable to send the Analogue signal to your Analogue screen.
    If you have a Source with a DVI-D Out you can only output Digital signals and you'll require an expensive converter box to convert the Digital signal to an Analogue signal before it hits the VGA in on the Screen - a cable cant do the conversion.
    See http://www.gefen.com/kvm/product.jsp?prod_id=1209
    Best regards
    Joe
  9. oblivion_6
    oblivion_6
    Mar 17, 2006
    140
    Glasgow
    +3
    hmm i think its DVI-I thats on the machine, it arrives on wednesday, no biggie if the cable ive bought doesnt work ill sell it :)
  10. oblivion_6
    oblivion_6
    Mar 17, 2006
    140
    Glasgow
    +3
    Guys I have to commend futureshop, ordered the cable yesterday morning and it arrive just there :) and the cable is superb quality
