5chan power to preouts 3802 where to purchase cheap rca in/conn please
Discussion in 'AV Receivers & Amplifiers' started by mick23, Feb 27, 2003.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    hi all will soon be recieving rotel 5 channell power amp (rb985) and wish to link this to denon 3802 using denons preouts.
    i currently only have a single spare rca/interconnect, so should i try with (bog -standard ones that come supplied with kit)
    i could do with some more ics 1/2 meter long as i might stack 3802 on top of power amp,
    any suggestions on (CHEAP) ICS, if i go the processer route later ics might be wasted if i get the db25-db25 rotel gizmo
    thanks all
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Try Richer Sounds.
    They do cables at both £10 and £20 per pair and both are very good value for money.
    3x £10 cables would be fine for connecting processor to power amps - though of course the better the cable slightly better signal that gets to the power amp.
    BTW - I wouldn't place the 3802 directly onto the poweramp ... the power amp will get quite warm in use.
    Vikki
