59 mins recorded - 0%!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by DaveP, Dec 21, 2004.
  1. DaveP
    DaveP
    I have a recording which shows as "Recorded", when I press play I get the synopsis saying recorded 59 mins but with 0% used. When I press play again it does nothing. Backup doesn't work and the only way out of the screen is to press planner or services.
    I've had this before when I started to watch a program that was still recording but this is the first time it's happened with an "un-touched" recording,
    Dave
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Dave,
    Happened to me once, a long time ago. Never did get to watch that recording. Never found out what caused it either.
    Delete it and hope there's a repeat of the programme!
    A. Dork
  3. DaveP
    DaveP
    Luckily it wasn't important. I read somewhere that it may be recovered if I do a planner re-build, but as it's a 250Gb disk that's half full, it's too big a risk!
    Dave
  4. Andrew K
    Andrew K
    Oct 14, 2004
    3,386
    +608
    I had the problem as well. Deleted the 0% recording and then found the program I had recorded under a different description on the planner. You may get lucky if you check the recordings around the one showing 0%.
