For Sale 5820k, X99 Mobo, Phanteks Evolv, watercooling parts (pump, res, etc)
Discussion in 'Computer Classifieds' started by crazy8s, Jun 14, 2018.
  1. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
    All items are boxed unless stated otherwise.
    Pics from when I first listed the items, hence dates. Can retake if required/requested.
    Depending on the value the items will be sent via DPD, RMSD or by 1st Class Signed For..
    Intel Core i7 5820K s2011 v3 - £140 delivered
    Purchased November 2015. Retail boxed. Note, this does not come with a heatsink and does not have an iGPU (in case buyers weren’t aware of the differences between Haswell-E and regular Haswell chips). I overclocked it for a few hours when I first set up my loop in 2015 but has been run at stock ever since.
    AsRock Fatal1ty X99M Killer/3.1 Micro ATX Motherboard - £110 delivered
    Purchased November 2015. Boxed with accessories.
    Phanteks Enthoo Evolv Black Micro ATX Case - £50 collected
    Purchased September 2015. This is the original Evolv (not the recent model). Boxed with toolbox, pump mount, PWM hub, etc. I believe most of the original parts are included in the accessory kit. Not sure if all of the original screws are in the toolbox but the attached picture provides a good indication of what is included. The original 140mm and 200mm fans were reinstalled in the case. There are some scratches on the top (see pics) and some marks/faint scratches on the window – though this didn’t appear as clearly in the pics and are more pronounced and whitish in colour.
    MSI GeForce GT 710 Passive Silent Graphics Card 2GB - £25 delivered
    Purchased March 2017. Was used briefly whilst my 980ti went for RMA.
    ************ Watercooling Parts ************
    Please note, all watercooling parts have been flushed with deionised water but it is recommended the buyer flush/clean these to ensure they are 100% clean and ready for your loop. I used clear Mayhems XT fluid for the loop but there has been a greyish tint to it when cleaning. I am sure more remains. I have had 0 leaks during the time the loop was installed (2015-2018) and the loop was dismantled in Feb 2018.
    AlphaCool NexXxoS ST30 240mm Radiator - £20 delivered
    Purchased November 2015. Boxed with screws. See pictures for marks/colouring/dust.
    AlphaCool NexXxoS ST30 280mm Radiator - £30 delivered
    EKWB 841013 RES X3 150 Reservoir - £20 delivered
    Purchased November 2015. Boxed with screws/fittings.
    Some marks on the tube but nothing major.
    EK 43031 XTOP Revo D5 PWM Pump - £50 delivered
    Purchased November 2015. For total transparency I had experienced some faint whine (not really audible when the side panels were closed) from the pump when I had mounted it on the back of my case using Velcro and cable ties, this went away after a while. I’m not sure if it was the pump or my method of attaching it to the case that did this.
    EK-XRES 100 REVO D5 – ACETAL Pump Top + Res - £30 delivered
    Purchased April 2017. This is a 100ml reservoir and pump top combo for the D5 pump. Some water marks remain inside the tube from where the water levels were in my loop.
    EKWB 830543 FC Titan X Acetal GPU Waterblock - £40 delivered
    This is a Titan X waterblock but fit the reference 980ti perfectly.
    Please note, one of the screws on the heatsink side came off (see pic, green circle, to see which one) when I removed it from the GPU. It does not appear to have weakened/loosened the block as there is a screw on the other side connecting the block. I don’t know if this will affect the seating. The copper side also has some blemishes as seen in the pics.
    EK 800171 Supr EVO Full Nickel CPU Block - £40 delivered
    Purchased November 2015. Used for the 5820k. Boxed.
    Fittings taken from my loop. Threads look OK. Pictures are posted further down.
    1x Bitspower Deluxe Dual G1/4" Fitting, White
    Used as part of a drain port.
    £3 delivered
    3x EK-AF Angled 90° Fitting G1/4 Nickel
    £16 delivered for all 3.
    9x EK-ACF Fitting 10/13mm Soft Tube Compression Fitting G1/4, Brass - Nickel Plated
    £26 delivered for all 9.
    1x Phobya 2-way ball valve G1 / 4 - knurled
    Used as drain port.
    £7 delivered delivered.
    2x Alphacool HF 13/10 compression fitting 45° revolvable G1/4 - Chrome
    £14 delivered for both.
    1x EK DuraClear 3M Clear Water Cooling Tubing 9.5mm/12.7mm
    There is about 2m left.
    £8 delivered
    Price and currency: various
    Delivery: Delivery cost is included within my country
    Payment method: BT
    Advertised elsewhere?: Not advertised elsewhere
    Prefer goods collected?: I have no preference
    ______________________________________________________
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via private conversation to each other after negotiations are complete and prior to dispatching goods and making payment:
      • Landline telephone number. Make a call to check out the area code and number are correct, too
      • Name and address including postcode
      • Valid e-mail address
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
  2. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
    Card and case
    MSI GT 710.jpg Phanteks Evolv 1.jpg Phanteks Evolv 2.jpg Phanteks Evolv 3.jpg Phanteks Evolv 4.jpg Phanteks Evolv 5.jpg Phanteks Evolv 6.jpg Phanteks Evolv 8.jpg Phanteks Evolv 9.jpg Phanteks Evolv 10.jpg
  3. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
    case toolbox
    Fittings
  4. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  5. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  6. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  7. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  8. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
    bump and price drop
  9. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  10. Viberious
    Viberious
    Dec 14, 2003
    623
    Didcot
    +21
    Interested in the d5 pump, you mentioned it's faint noise. What speed setting was it identified? Is this molex or sata powered?
  11. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
    I kept it on silent mode on my motherboard BIOS so not sure what % that would be, but <50% I believe.
    It is molex powered.
  12. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  13. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  14. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  15. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  16. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  17. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  18. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
  19. crazy8s
    crazy8s
    Oct 14, 2007
    1,536
    48
    +46
