580p through 360
Discussion in 'Xbox Forums' started by brandondanger, Jan 1, 2007.
  1. brandondanger
    brandondanger
    Nov 23, 2005
    708
    dudley
    +10
    ive just tried my first dvd in my 360 (hd component cable) and the picture is miles better than through my sony dvd player running an rgb scart. but im a little confused, my tv is saying that the input signal is 580p. does this resolution seems high for a non upscalling dvd player, which is what the 360 is... or have i got my wires crossed?
  2. noshoulders
    noshoulders
    Apr 5, 2005
    451
    28
    +29
    360 does upscale!
  3. Guns_LotsOfGuns
    Guns_LotsOfGuns
    Moderator/Games Reviewer
    Jul 19, 2006
    8,179
    Tumbling down the rabbit hole
    +3,312
    I thought that was only through the vga cable though?
  4. sammy4499771
    sammy4499771
    Mar 12, 2006
    589
    +93
    The 360 only upscales through VGA.
  5. brandondanger
    brandondanger
    Nov 23, 2005
    708
    dudley
    +10
    im running a component cable though, is this an upscaled res? 480 is sd resolutuion isnt it? i did know my ntsc and pal resolutions but its been so long since i had to think about it that im just not sure anymore...
  6. sammy4499771
    sammy4499771
    Mar 12, 2006
    589
    +93
    480 is NTSC format. Mine displays at 576p.
  7. brandondanger
    brandondanger
    Nov 23, 2005
    708
    dudley
    +10
    yep, 480 ntsc and 576 pal. all i can think is that either my dvd player has been outputting at 480 or the prog scan is making all the difference...:confused:
  8. ukkev2000
    ukkev2000
    Apr 12, 2004
    1,027
    48
    Hampshire
    +51
    the 576p signal is only 145 y lines off 720p whereas the RGB signal would be interlaced.
