576p/50Hz & 480p/60Hz display modes
Discussion in 'Projectors, Screens & Video Processors' started by ddavewoods, Aug 1, 2005.
  1. ddavewoods
    ddavewoods
    Jul 24, 2005
    561
    +39
    sorry for the newbie question.
    when I put a uk sourced disk in my DVD player connected through component connections, the plasma comes up with 576p PAL.
    I play a disk sourced in japan and the plasma diplayed 480p PAL.
    both pictures look fantastic
    the specs of the panel say 480p/60Hz & 576P/50Hz. amongst others
    I was just wondering why the different display modes, there is nowhere to select the mode manually on the player, so I guess it must detect what sort of disc is inserted ?
    cheers
    Dave
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    This is just a pure guess, but.......
    your DVD player could be set to output PAL only. Therefore when it plays an NTSC disc it converts it to PAL, but the resolution is obviously not changed.
    Have a look in the setup menu and see if there is an output setting. If set to PAL then try changing it to 'auto' if available. Otherwise it means sticking with it the way it is or manually changing to NTSC each time you play an NTSC DVD.
    Mark.
  3. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    Japanese discs are NTSC
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    That sounds very odd. I didn't think there was such a thing as 480p PAL? Also, 480p isn't a PAL or an NTSC signal. PAL and NTSC refer to interlaced images.
  5. ddavewoods
    ddavewoods
    Jul 24, 2005
    561
    +39
    hi
    thanks for the replys, i shouldnt have posted while drunk, lol, it doesnt say PAL after the 576P / 480P at all, just component 1 576p or 480p
    Crispy was correct the Jap disc is NTSC and therefore 60Hz so the TV displays it at 480P/60Hz.
    The UK discs being PAL 50Hz are displayed at 576P/50Hz.
    thanks again
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    +37
    lol
  7. Bails
    Bails
    Oct 15, 2003
    203
    +3
    That's true in that the discs themselves will be either 576i (PAL) or 480i (NTSC), the 'i' standing for 'interlaced'. A progressive scan dvd player will then de-interlace the signal from those discs and output 576p and 480p respectively, the 'p' standing for 'progressive'. The result will almost always be better picture quality.
