576i (HDMI) from the 868i to IScan HD+ - How would you rate it´s PQ?
Discussion in 'Projectors, Screens & Video Processors' started by artoj, Jul 2, 2005.
  1. artoj
    artoj
    Nov 21, 2004
    80
    Hi !
    Has anyone tried 576i (HDMI) from the 868i to IScan HD+ and if so how would you rate it´s PQ ? Also has anyone compate it against SDI and if so which one did you prefer ?
    I´m also interested in if I outputed 765i(HDMI) from 868i to IScan HD+ could I still adjust gamma etc. in 868i ?
  2. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    The 868 HDMI works well with the HD+, Use 576P instead of 576I, although I think 576I looks a bit sharper than 576P, you also see a lot of Interlace shimmmer, I think DVDO still have some work to do with 576I over DVI
  3. artoj
    artoj
    Nov 21, 2004
    80
    Thank´s Chris5 for your answer :smashin:
    How about that gamma issue ?
  4. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    what gamma issue?
    I have the 868 set to 'DIRECT' setting
  5. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,185
    Welwyn, Herts
    +866
    There's a new firmware update for the HD+ to accept 480 i and 576i.
    A glaring omission beforehand, caused, I believe, by the DVI interface standard that specifies a minimum data rate threashold based on VGA rather than SD video that disables the input.
  6. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    that's what I'm using
  7. artoj
    artoj
    Nov 21, 2004
    80
    That:
    I´m also interested in if I send 756i/480i(HDMI) from 868i to IScan HD+ could I still adjust gamma etc. in 868i ?
  8. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    you can adjust gamma fron the 868 but you should not need to set gamma on the 868, just use the Direct setting and make any required brightness/contrast adjustment on the IScan. I think currently 576P from the 868 is better than 576i though
  9. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Correct me if I'm wrong, but I don't think you can set the 868 to interlaced-thru-hdmi.
    576p is however the way to go on the 868 because component video is rather mediocre.
  10. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,495
    Norfolk
    +168
    868 will do interlaced over HDMI. One of the few players that will.
  11. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    Hi Barend,
    I'm afraid I'm going to have to correct you, you can :)
    whether your receiving equipment supports it is another matter.
    the ISCan HD+ beta software does.
