565a to 935 worth the change?
Discussion in 'Blu-ray & DVD Players & Recorders' started by mickey, Jul 16, 2004.
  1. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    hi , can any of you guys honestly tell me if it would be worth me changing from a pioneer 565a using component output to a samsung 935 using dvi output to my AE500 projector, Like would I see the difference. all opinions welcome. thanks Mike
  2. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    Bump!!! :)
  3. inzaman
    inzaman
    Dec 16, 2002
    7,966
    Derby
    +1,034
    Does the 565 do progressive scan?
  4. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    hi, yes it does but i dont use it since I think the picture is better without it on my ae500
  5. inzaman
    inzaman
    Dec 16, 2002
    7,966
    Derby
    +1,034
    On my Z2 i think that Progressive looks better, must be the dvd player handles this better than the internal scaler.
    My view on the 935 compared to my pio 757 is this, the 935 for NTSC material gives an absolutely superb picture and is pin sharp but for PAL i preferred to pio 757, so sold my 935 as i didnt want two dvds doing one job.
    I am now waiting for other companies to introduce dvi to their dvd players then will try again and once prices have fallen slightly.
  6. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    On my HS20 it it definitely worth it, I have them both, so had the choice.
    Whether that translates though...
    The user interface is far better on the Pioneer btw
  7. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    MIkeaitch.. I notice that you also have the yamakawa 365 to your pj how does this compare to your 935 as I dont watch that much ntsc really i would like a player that would give me 1280x720p at 50hz if possible. do you have the two of them for this reason. cheers Mike
  8. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    Mickey
    I bought the yammy to access divx, and also custom resolutions to get near 1:1 pixel matching.
    It gives a smoother , but slightly softer picture than the Samsung, but probably is the better overall choice for flexibility and can be firmware upgraded. It is a little fussier about scratched discs tho, and build quality is nothing special.
    I'll keep them until the mainstream players come out but in my book, DVI is the way to go
