56 plate Focus 1.6 TDCI steering problem
Discussion in 'Motoring' started by wack, Feb 25, 2013.
  1. wack
    wack
    Jul 21, 2005
    4,290
    Warrington
    +831
    M having a problem with the steering, bizarrely it's heavy when turning sharp left
    I've taken the headlight out and had a look at the electric PAS pump and it looks OK, no kinks in the pipe or leaks, the fluid is at the max mark
    Before I go down the £600 new pas pump is it likely to be anything else
    Most of the time it's fine but when I pull into the close where I live I do a sharp left turn to reverse on the drive , it's like the PAS isn't working at all as you get towards full lock, turning right to full lock and it's fine
    Weird
  2. Delvey
    Delvey
    Jul 20, 2008
    9,217
    Manchester
    +2,865
    Could be some component thats broken so when turning left is rather catching or not turning properly. An example would be top strut bearing
  3. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    Either bent suspension or the pump, my dads corsa had the same symptoms, corsa c new pump fitted £400 ouch.
  4. wack
    wack
    Jul 21, 2005
    4,290
    Warrington
    +831
    I don't think anything is bent or damaged as it doesn't do it all the time, it's looking like the pump
    Thanks for the advice though :)
