55XE9305 Vs 55XF9005 (Swap offered)
StoufferTheCat
So I've been having some issues with my 55XE9305.
I managed to get thunderflies in my first one and then the replacement Sony sent me constantly flickered off/on. After a week of "emotional discussion" with Sony they have at last agreed to swap my TV over again.
However they don't have any XE9305's available and have said as per terms & conditions they swap with a "better" model and have offered and arranged for a swap fort he XF9005.
Can anybody tell me what I'm going to lose by accepting this swap?
I'm not sure what options I have, I'm guessing I could ask Sony to repair it. I can go back to John Lewis but I'm assuming in the first instance they just contact Sony, and we'll be back to where we are now.
Thanks all
LCDseeker
Thanks all
I'm in exactly the same position. I'm not sure the XF9005 is equivalent is it? It has a much lower price than the XE had this time last year. The stand is also awful.
Norman
The XF9005 is inferior in almost every respect. The AF8 OLED sits in the price range previously occupied by the XE9305, and that’s what I demand it replaced with, or the ZD9 (I do know they swapped out some 65” XD’s for ZD9, so you might get lucky).
StoufferTheCat
Well now I don't know what to do.
So The XE9305 is faulty, there is no coming back from that.
It's now too late to give Sony a call, so that will have to wait until Monday.
If they have no more XE9305's then I guess they cannot make one magically appear.
So can anyone tell me specifically why the XF9005 is inferior to the XE9305? There is no point me calling Sony on Monday without at least a good argument why it isn't as good.
How do you even go about saying "No, this isn't as good"?
desinho
1. Brightness XDR Contrast rating of 10x on the XE93 vs 6x for the XF90 (translated into peak brightness of close to 1500 nits vs bordering on 1000 nits. HDR is much more impressive on the XE93)
2. Sound: 3-way speaker system on XE93 with front guiding duct
3. Build quality: XE93 weighs almost twice as much, built like a tank
If it were an 'upgrade' the line wouldn't trickle down would it ... just like it doesn't here
Norman
Peak brightness a lot lower (1400 nits vs 1000) so HDR inferior
Superior Build quality (XE93 built like a tank with full rear panel covers, The XF is very plasticky and cheap by comparison).
Audio is also better on XE93 (probably unimportant).
Edit: forgot to add, the XE93 also has superior local dimming
Keep in mind the XF9005 is the direct replacement for last years XE9005, not the XE93.
If I were to end up in your position with my 65XE9305 needing replacement, I’d settle for nothing less than a ZD9, but since Sony now don’t offer a higher range 55” LED beyond the XF, you might not have any other option but to accept their offer.
LCDseeker
That's just about settled it for me. If Sony don't offer me a ZD9 or another XE then I'm going to demand a full refund.
LCDseeker
Thank you for this post. It's EXTREMELY useful for me. Do you have much knowledge on the AF8? I'm not convinced about OLED technology yet especially in the lower price range.
StoufferTheCat
So, I think I need to speak with Sony on Monday.
However, if they don't offer me anything other than the XF90 I don't see what options I have. I didn't buy it directly from Sony, so I'd have to go to John Lewis. Who will take the TV away and I expect it'll go to Sony.
So Sony might repair it, but if Sony then say to John Lewis - no, buggered, we'll give you an XF90 again I don't see what options I have.
Norman
I’m not too knowledgable on the AF8, but if I were buying now I’d still be worried about OLED screen burn (due to my household watching a lot of “wrong” content).
I honestly don’t know what I’d buy now, but I do know I wouldn’t accept a downgrade under any circumstances.
If they won’t swap for a ZD9 (I assume your XE93 is a 65”), then I’d push for a refund.
StoufferTheCat
It's not, it's a 55 - but I don't suppose that should make a difference.
I'll call Sony on Monday and explain that local dimming is worse, which is important to the onscreen blacks. That peak brightness is lower, which in turn effects HDR performance.
That they are offering a newer, however inferior TV as a replacement and I'm not willing to accept that.
I think at that point I will have to allow them the opportunity to repair my XE9305 - which I'll accept and then see what happens.
LCDseeker
Unfortunately it's a 55XE so I think I'm scuppered.
LCDseeker
They don't repair the panels as it's not cost effective.
StoufferTheCat
OK, lets approach this from a legal point of view then.
I call them up on Monday and I say "I've now reviewed the TV you are offering me in return - I feel it is inferior because of worse local dimming, lower peak brightness and inferior HDR performance. I'd like either a model of equal or higher specification".
They respond with "Nah, it's the XF90 - final offer".
What can I actually do at that point? I mean who decides what is a better/inferior model?
I could go the retailer route, but they will effectively acting as an intermediary between me and Sony - so if Sony tell me retailer the XF90 is comparable - I'm SOL?
LCDseeker
What warranty so you have with the retailer? If Sony won't offer a like for like replacement which they can't because this year they didn't make one equivalent the the 55XE, then they can only offer the XF or the different model like the oled. I think you (and I, being in the same situation) have a right to go back to the retailer and ask for a refund.
StoufferTheCat
I fully agree, but I wonder what my retailer can do.
I purchased my TV with a 5yr warranty - effectively the first year is with Sony and the last 4 with the retailer.
I actually called them up when Sony were being less helpful and I was told they would collect the TV, Sony would assess it and what happens next would be decided by them - they will be paying for any repairs etc.
So all I see my retailer being is a middle-man between me and Sony and I think they will get the same result.
IF I can convince my retailer that the offered TV is of lower specification than what I bought then I'd expect them to replace with better or offer me a refund - I'd take either.
I'm going to phone Sony on Monday and explain the situation. I won't get upset yet because I've not given Sony the opportunity to revise their offer.
The ZD9 I know is a lot higher specification than what I have - but it wont' cost "that much more" to Sony.
Question - was the XE9304 ever a thing?
The ZD9 seems a fair compromise, but of course I'd say that. The AF8 is the technology I avoided when I choose the XE9305, but I'd probably take that over the XF9005 too.
What I'd do with a £1300 refund I don't know - but that would at least give me the opportunity to do me research again and purchase the best for my money, when the XE93 was.
StoufferTheCat
Thanks for all the input.
I've nothing else to add until I speak with Sony on Monday. I will report back just for closure on the thread.
With my TV being a 55" I'm really looking at the following options:
1. They find me an 55XE9305
2. They offer me a 65XE9305
3. They offer me a 55AF8 (would have to long hard think on this as it's OLED)
4. They offer me a full refund
Now time to work on my script :)
LCDseeker
Please do let us know as I'm in a very similar situation. I hope you get a satisfactory outcome. I'd personally take the money and go shopping again.
desinho
"Can I claim with the manufacturer or the retailer?
If your product develops a fault, your rights to make a claim and get your money back lie with the retailer who you purchased the product from.
Don’t be fobbed off by retailers who encourage you to go to manufacturers in the first six months. Remember, it’s down to you – you have the right to pursue a faulty goods claim with the retailer rather than a warranty or guarantee claim with the manufacturer.
If you want to make a claim using your manufacturer guarantee or warranty, your route to claiming would be to your warranty provider, who is often the manufacturer."
When can I use a manufacturer's warranty or guarantee?
Factory warranty is always a bonus, they should 'never' be your first contact to claim warranty. It may make things simpler but really you are letting the retailer, where the responsibillity lies, off the hook.
They don't even have to offer you another Sony per se I believe but maybe that's your personal choice of brand.
StoufferTheCat
First update (for anyone interested) is unfortunately not much of an update.
Explained over the phone the issue I had, I never know how technical the people I'm speaking with are. She started explaining again that they were replacing it, as per the terms and conditions, with a TV of equal or better. I stopped her and explained it wasn't - mentioning local dimming and HDR as the two main reasons and those being two features I specifically looked at when choosing the XE9305.
She then said "So really you just want another TV the same as you've currently got". Yes I exclaimed. She is speaking with the "Central resourcing team" and I've got a call back tomorrow afternoon between 2:00pm - 4:00pm.
Ideally they will manage to locate me another 55XE9305.
If not I'll be pushing for either a 65XE9305 or 55AF8.
I really don't want the refund if I'm being honest - what do I spend £1300 on right now? So my third option will be I accept the 55XF9005 and ask for a rebate of £300.
I'll keep you posted after tomorrows discussion.
Mortey
I hope it works out for you. However good the 9005 is it is not a replacement for the 9305 from what I saw and what I read.
LCDseeker
I think you are doing the right thing. I hope they can find you another XE! If not stick to your guns as the XD is inferior so you do right to ask for money back. It's dawned on me 55" Sony owners are high and dry at the moment.
Mortey
Yes it does seem that way. Thankfully mine is okay at the moment but it does worry me for the future, mine came with a 5 year Sony warranty so I am stuck with them!
Cameron583
Where did you get the TV from? That's who you should be having the discussion with, not Sony
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
Trending threads
Latest News
Sky comedy panel shows back to film new series
  • By Andy Bassett
  • Published
Polk launches MagniFi 2 soundbar
  • By Andy Bassett
  • Published
Samsung pulls out of IFA 2020?
  • By Andy Bassett
  • Published
AVForums Podcast: 28th June 2020
  • By Phil Hinton
  • Published
LG Soundbar UK prices and availability for 2020 confirmed
  • By Andy Bassett
  • Published
