Answered 55XE9005 or LGB7
Discussion in 'What Is The Best TV For You?' started by Dirtschmooz, Jul 11, 2018.
  1. Dirtschmooz
    Dirtschmooz
    Apr 1, 2005
    3,984
    +663
    £950 and £1200 respectively
    Xbox one x and ps4 pro. Sky hd now buy sky q soon. watch lots of footy.
    Sit 3meters away max
  2. Best Answer:
    Post #2 by zeppelino, Jul 11, 2018 (1 points)
  3. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    Best Answer
    B7 is far superior. However given the viewing distance you should consider going up to 65”.
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  4. Dirtschmooz
    Dirtschmooz
    Apr 1, 2005
    3,984
    +663
    wish i could, but not gonna fit. More like 2.5 m as just measured
  5. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    You will want to get the highest quality TV you can get if you can't upsize as your gains from UHD will be limited to none at that distance from a 55". Be wary to spend money on any UHD non HDR sources like SkyQ. At 2.5m I can't notice when amazon switches to UHD from FHD on my 65" TV. I have to be around 1.4m away to notice a difference.
    Also beware of having to game at lower frame rate in some titles if you use UHD.
  6. Dirtschmooz
    Dirtschmooz
    Apr 1, 2005
    3,984
    +663
    cheers for help all. sky q i will get for free. i appreciate the limitations of not being close enough to maximise benefits. despite that, i only have 50” tv at the moment, so size increase and improved Pq should help
  7. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    Yes, most people don't or can't sit close enough to benefit from UHD but resolution is only one part of the story, you will see gains elsewhere from higher quality sources no matter what the resolution. With Sky for example you will probably see the UHD channels look better because they transmit at higher bandwidth, not because they are higher resolution compared to HD :)
  8. Dirtschmooz
    Dirtschmooz
    Apr 1, 2005
    3,984
    +663
    Xf9005 for £1300 or b7 £1200
  9. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    B7
  10. MEGATAMA
    MEGATAMA
    Oct 13, 2017
    255
    2
    47
    Berlin
    +141
    When i see questions like this in my had is....golf gti vs ferrari....for same price.
    Lg b7 is correct answer
  11. Leo31291
    Leo31291
    Jul 22, 2010
    1,728
    116
    London
    +1,259
    Yeah but the Ferrari will be more expensive to run and maintain...
  12. Dirtschmooz
    Dirtschmooz
    Apr 1, 2005
    3,984
    +663
    ordered B7 £1174 from RS. the xf9005 is same price at co op, but the OLED seems a better bargain. thanks for peoples help
  13. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    Stonking deal that!
