I've just bought my first OLED screen, an LG 55B7 which I'm amazed with.
However, although the curved metal base looks smart, it is longer than the Sonos Playbase that the TV sits upon, so that the metal legs protrude the Sonos by a couple of centimeters each side.
Whilst it is a small thing, I was wondering if I had any options.
I've seen photos of the LG 55B6 model which appears to have a much more compact black/glass base.
Does anyone have this model, and if so, are you able to measure the width of the TV base and post here, please? From the pictures it appears narrower than the 55B7, but even looking at LG webpage specifications, the base width doesn't appear to be listed. The Playbase width is 72cm for the record.
Does anyone know if the 55B6 and 55B7 base interfaces are identical?
I'm wondering if I could get hold of a 55B6 base and base-fitting, I might be able to replace mine with the narrower 55B6.
If someone could post 55B6 base width, and/or know answer to above question, I'd very much appreciate that. Also, any thoughts, other suggestions would be appreciated.
Thanks.
Tom
Thanks.
Tom
