Dave Wishart
I'm needing to replace my venerable Sony and looking for something reasonable long term. It's in a room with a window behind it with viewing distance between 8.5' to 9'; is exceeding unlikely the boss will let me rearrange. The material will be in order of most watched:-
The default option seems to be the LG C1 but im wondering if being in a bright room will be a hinderance and whether the Panasonic TX55JZ1500B or Samsung QE55QN95A/QE55Q80B or Sony 55A84J would be a better option. I had discounted the LG G1 as other comments here suggested the £300 uplift wasn't worth it however this post from @Dodgexander suggests the LG 55G1 may work better for me:-
The final option is to wait out and see what the CS series is, see here as the new Alpha 9 Gen 5 processor may be a compromise over the unaffordable, for me, C2.
Irrespective of which display, I will need a VESA mount so I can place the current and future upgrade centre speaker; the current shortlist being:-
RFIVER Universal Swivel Table Top TV Stand Base TV Stand Replacement for 50 55 58 60 65 70 75 80 inch TVs with Height Adjustable Mount Bracket Cable Management max VESA 600x400mm max 50kgs
FITUEYES Swivel Table Top TV Stand for 50" to 85" LED OLED LCD Plasma Flat Curved Screens Heights Adjustable with 10mm Tempered Glass Base Cable Management & Holds 50kgs/110LBS Max. VESA 600x800mm
These may be a little overkill but I don't want an issues with a stand not holding the weight.
Thoughts?
- Streaming from Disney+/Netflix/Synology NAS
- Disc playback from PS3 which will be upgraded sometime to something (x800M2/UB824)
- Linear HD TV
Uses new OLED panel with better durability, increased brightness for an astounding HDR picture, and better at coping in brighter rooms.
Thoughts?
