55" Toshiba Rear Projection TV *HELP*
Discussion in 'General TV Discussions Forum' started by fatfingers, Jan 26, 2003.
  1. fatfingers
    fatfingers
    :( I bought this TV in 1995/6? and as others have said in this forum, 'it was one of the best purchases i've ever made'
    HOWEVER....... It has developed a fault
    The left hand third of the screen now has what looks like a convergance problem. the remaining two thirds is still perfect
    I would have thought that if it were a worn tube then the problem would be over the whole screen so i'll rule that one out for now.
    Local TV repair men (northamptonshire) don't know much about RPTV's so I thought I'd start here
    1. Anybody know of this fault?
    2. Does Toshiba have a tech department/website/telephone no?
    3. Does anybody know of a firm with the skills to fix RPTV's in
    my area (i live in Rushden Northamptonshire)
  2. cdrman
    cdrman
    Dec 11, 2002
    9
    this is the number for tosiba custromer helpline 01159766958
    hope that helps
