55" Samsung.
Discussion in 'TVs' started by Cyglore, Apr 8, 2003.
  1. Cyglore
    Cyglore
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Your link is dead ;)
  3. Cyglore
    Cyglore
    its the SP-55W3HF. If you type that in the search box (using model code) you can find it. It seems that there is no way to link to it directly.
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    I've just looked at it... for £1900 it does seem good value... unless one sees the picture live it's hard to give it a good recommendation though.
  5. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    The Samsung RPTV's are generally very nice looking machines,but have the usual LCD failings of relatively low contrast and poorer performance in high ambient lighting.
    I bought a CRT Rear Pro TV(see below) for just those reasons having seen several TV's of both CRT and LCD type,and havent regretted the decision one bit...best way to decide is to see a few together,and decide that way,using a good DVD feed from a well known disc,and not the shop's own TV feed,which will usually be poor quality
