55 inch
Discussion in 'Plasma TVs Forum' started by Lone Granger, Nov 8, 2004.
  1. Lone Granger
    Lone Granger
    Jan 6, 2004
    269
    Northants
    +8
    Which of following would give best performance, particularly for HD:
    Fuji - DVi Jan 05
    Hitachi - currently with DVi
    Fuji would have me believe theirs is set up best, however Hitach has received rave reviews
    I have viewed Fuji on HD and have no complaints - also reasonable value at c £5k (Hitach cheaper still)
    Saw Pio 61" as was NEC, with HD - stunning, as it was last year as NEC - what have Pio done to change NEC and how has price changed?
    £12k is a stumbling block...... - Now if Pio had a 55" at £4k, life would be a bit more exciting..!
    Having seen good HD on an out the box Fuji, I think the time to buy is imminent as a better picture at that size would be hard to discern.
    Whereas, it is worth waiting on the projector front as a pixel matching Blue Laser projector is just around the corner (c 2000 x 1000?)
    Saw Sony's demo of Blue Laser - terrible! - Said as much to their techy and he replied -'bad cables, crap projector......' - then why use rubbish to show off blue laser?>???!!
    Found Hitachi chaps v helpful - even invited me down to H.O. to test out my source H/W with their 55" cinema set up for a few hours!
    Mmmmm - HD on a 60" + ...................surreal!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    So are you looking to buy? Ireconmend you look at DEMO the OPtoma 65" DLP RPTV and the Sharp 45" LCD
