55" Hisense U7A vs N6800
Discussion in 'What Is The Best TV For You?' started by Gearsik, Aug 6, 2018.
  1. Gearsik
    Gearsik
    Aug 6, 2018
    2
    4
    Swansea
    Hey gyus,
    I just got my PS4 Pro and for the first time in my life decided to get a TV (I've been playing on monitors all my life) As I've just missed best deals during the prime day and many good TVs are out of stock I'm not really sure what should I get as it will be used about 50/50 for gaming and watching TV shows/movies on Netflix etc. I often play and watch in a quite dim room and I don't want to go lower than 55".
    Unfortunately I can't afford to get myself an OLED TV. I was thinking about getting Samsung MU7000/7070 but it's hardly available and its price is quite high atm. My budged is up to 600 pounds. I found Hisense U7A and N6800 to be often recommended as great TVs under 600 but I'm not sure about any of them, are they best TVs I can get for up to 600? If so what is the difference between them? It seems like even though U7A is newer, is also inferior to N6800 isn't it? What about other brands like LG or Sony? Don't they have anything in that price?
    Many thanks for your help.
  2. Angelo M
    Angelo M
    Jan 25, 2015
    576
    Terlizzi
    +79
    Better the new 55U7A.
    It has 120 hz panel, the other only a 60 hz one. :)
  3. Dodgexander
    Dodgexander
    May 29, 2007
    15,190
    +4,401
    U7A if you can't obtain the MU7070 or MU7000.
    The N6800 is more and likely enough though, especially for gaming.
    So if you can save quite a bit going for that instead go for it.
    If it's close in price to the U7A get the U7A instead.
  4. Bluehedgehog83
    Bluehedgehog83
    Aug 8, 2018
    15
    3
    London
    +5
    I just got the 55u7a and I’m blown away pictures fantastic and for gaming it’s amazing I loaded up cod ww2 on my Xbox one x on it, hdr worked straight away and didn’t get any lag in online multiplayer, I’d recommend it.
  5. Gearsik
    Gearsik
    Aug 6, 2018
    2
    4
    Swansea
    I found UE55MU7070 for 699 and decieded to go with it. Gonna have to do some overtimes but I guess it'll be worth it. TV will be with me on Monday.
  6. Hbo212
    Hbo212
    May 21, 2018
    293
    Uk
    +41
    Hi how's the black levels performance? Noticed any blooming?
