512MB Flash Player
Discussion in 'Headphones, Earphones & Portable Music' started by lilpaul, Mar 10, 2005.
  1. lilpaul
    lilpaul
    Mar 10, 2005
    9
    Im looking at buying a flash mp3 player and was after some advice.
    I mainly want to use it for the gym, and would like to have enough space to fit a couple of live dj sets on so 512MB is really the minimum size.
    It also needs to be small and if possible have a radio for when i get bored of listening to the mp3s. Cheap would also be good.
    Any ideas?????
  2. JuzzyD
    JuzzyD
    Nov 18, 2004
    225
    28
    +24
    Look at the Creative MuVo TX FM 512, should answer your needs (about £60-70) and comes with a strap so that you wear it on your arm
  3. yageaki
    yageaki
    Sony NW-E99 Mp3 Player is a 1GB MP3 players. It plays MP3 and ATRAC3plus compressed files and have a small blue backlit LCD screen. Since it is flash memory based devices, you will get an impressive 70 hours battery life out of these babies.
