50PV500 & Crystalio Timings?
Discussion in 'Projectors, Screens & Video Processors' started by fuzzb, Sep 24, 2005.
  1. fuzzb
    fuzzb
    Hi, I am just trying to set my Crystalio up with my Panasonic 50PV500 (1366x768 res). I have a picture displaying at 1366x768 but the refresh rate is 56Hz. I'm not sure if it is related, but the Crystalio is currently making football games more 'movie like' i.e. not as fluid, less sharp and a bit of judder.
    Does anyone have the correct timings for 1366x768 (1:1) for a 50PV500?
  2. madshi
    madshi
    Jul 18, 2005
    1,159
    48
    Hamburg
    +62
    The refresh rate must be 50Hz, otherwise you'll get FRC (frame rate conversion), which will result in motion judder.
  3. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    you also need to check the film bias is set to the minimum setting, and the detection window is set to small. Finally, check that you are judder free by looking at a news channel with a scrolling ticker tape, it should be smooth.
    good luck.
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    fuzzb, send me a private message and I will give you my number, give me a call and I will talk you through what to do to get 1:1 mapping at 50 and 60Hz.
