50PQ300 'PC' Input label. What does it do?
Discussion in 'Plasma TVs Forum' started by rovex33, Jun 16, 2009.
  1. rovex33
    rovex33
    May 1, 2008
    744
    +44
    Does anyone know what labelling an HDMI input as ''PC' actually does? Ive noticed if i do this for my PC the screen flickers a fair bit, but doesn't if i select 'Blu-Ray' as the input label. It also seems to change the overscan settings. My PC is mostly used for Blu-rays and MKVs so ive set it for now to 'Blu-ray'.
  2. Aeryn
    Aeryn
    Basically it disables most video processing, sending a more raw signal to the screen. With this option, you're TV acts more like a regular PC LCD monitor.
    You can read more about it here.
