50MXE1 RGB input
Discussion in 'Plasma TVs' started by mbower, Dec 3, 2004.
  1. mbower
    mbower
    Hi. Does anyone know if the 50MXE1 with PDA-5003 defintely does support RGBs because the manual for the PDA-5003 shows you how to connect RGBs using HD as hs/vs the manual also states that it is RGsB compatible. I cannot get RGBs from my STB to display a picture so is the manual contradicting itself? A picture appeared by removing green and putting sync in it's place but there was noise on the image. I was amazed that green did appear though? Can you combine the green and sync cable if only RGsB is supported.
    Any clarification on this is much appreciated.
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    That sticking the sync on green and getting a picture is the giveaway. You need to tell the screen in it's menu to look for a RGBs signal, as it's set on component now.
