50mxe1 and PC
Discussion in 'Plasma TVs Forum' started by Johnny Thunder, Mar 5, 2005.
  1. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    To connect my PC up to my display, do I just connect output from
    gfx card, to rgb d-sub input.
    Gfx card is a Hercules Prophet 9700 Pro(Radeon).
    Cheers.
    Johnny.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Johnny,
    Just set up a 1280x768 @ 50 or 60Hz resolution and you will be good to go. I take it your graphic card doesn't have a DVI connector.
    Steve
  3. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    It has a DVI-I output, my display has a DVI-D input.
    Can I connect this way..........
    Thanks Dutch.
    Johnny.
  4. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I have a few options that I am considering on this subject.
    If I can use dvi.....I will.
    Can I get a cable to join my plasma to THIS card.(quick google)
    Also, would I be wise to install any other cables for future use, ie.hdmi.
    Need to do it now, while I am in the process of rebuilding.
    Thanks all....
    Johnny.
  5. TheCrow
    TheCrow
    Jul 16, 2004
    734
    2
    43
    London
    +152
    Hi Johnny,
    Yes you can use the DVI connection, that's how I am driving my 50MXE1 but I am using an nVidia 6600 graphics card.
    Any standard DVI-DVI cable should work.
    Getting it to work at 60Hz (NTSC) is not too difficult, but 50Hz (PAL) is a struggle.
    I ended up using Powerstrip to set the correct timings by trial and error which required a PC monitor on the VGA output so that when the plasma didn't sync I could still see what I was doing!
    I wouldn't bother with HDMI as the plasma does not support HDCP so you wouldn't be able to watch copy protected sources anyway. At least until someone releases a HDMI(HDCP) input board for the display.
    Good luck and enjoy
    Paul
  6. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Thank you...... :smashin:
  7. soiaf
    soiaf
    Jan 23, 2005
    28
    3
    Could you post the powerstrip timings you eventually ending up using? You might be able to spare others the 'fun' you went through :)
  8. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Could you please recommend some QUALITY cables, it will need to be a good one. Once it is under the floorboards, I am stuck with it. Also, I may gamble on putting a hdmi cable in while I am at it, you never know......... :boring: ;)
    The cables will need to be approx.6-7metres long.
    Cheers everyone.
    Johnny.
