50Hz vs 100Hz and TV's with progressive scan input
M
MKD
Hi guys,
Panasonic is offering a CRT TV(TX-29PX20) with DVD progressive scan input. What does this mean? Is it going to work only with a progressive scan DVD player or it will work with any other DVD player.
My other question is concerning the 100Hz TV’s.The TV signal I get is 50HZ. Is the 100Hz TV going to change something?Is it going to make the picture any better or worse, or the picture will not change?
Thank you very much in advance to everybody.
MKD
spocktra
Established Member
For a pure progressive scan,dvd must have prog scan function.As for 50 vs 100htz ,the opinion has always been a split decision .Basically it is down to how your own eyes see the picture.Try to get some good demos of material that you watch[sky,dvds etc].Then you can see first hand the differences.
M
MKD
Thanks a lot spocktra.
So,I don't get any advantage of the progressive scan input if my DVD doesn't have the function.I'll go to the store and see the differences.
spocktra
Established Member
No both units have to be progressive capable.A demo would be a good idea, as not everyone prefers progressive to interlaced scanning.Some older dvds look worse on progressive scan.Most newer discs look fantastic.
M
MKD
Ok,I'll check that but what about a manufacturer?Is panasonic ok?or Sony is better?
M
MKD
By the way,the set is going to be 4:3 format and 29".Any ideas for a good TV?What about the new Panasonic 28PM11?
spocktra
Established Member
Both Sony and Panasonic are excellent brands.At the end of the day its down to what you prefer.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
