50hz or 75hz via vga
Discussion in 'Desktop & Laptop Computers Forum' started by fallwood, Oct 22, 2004.
  1. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Is it possible to set a 50hz or 75hz refresh rate on a ae500 using the vga output on a radeon 9600se and still maintain 1280 x 720 resolution. Tried doing it through powerstrip but it seems to default back to 60hz all the time.
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Are you saving as a custom resolution?
    You need to specify Desktop size and refresh rate etc... if you want to save in powerstrip as a custom res :)
  3. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Re-installed powerstrip and now i can change the frequency (weird), only problem is i get a blue bar at the bottom of the screen and cant seem to get rid of it, ive used the auto setup in screen position (on projector) but it doesnt seem to stretch the screen out enough. This happens in both 50 and 75hz modes, if i try to stretch or shrink the screen in powerstrip it changes the hz rating the more i stretch. Are their any settings available for vga as the ones for 50hz dvi give me the blue bar syndrome.
  4. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Am I the only person trying to do this through vga, would it be easier to install my dvi cable as ive read that its possible through dvi.
  5. ZahirB
    ZahirB
    Jun 14, 2004
    3
    I don't think anyone's managed 50/75Hz yet via VGA.
    I can get 50/75 Hz via DVI using a Radeon but not using NVidia.
    You should definitely go for the DVI route. The quality is so much crisper even with the cheap DVI-D cables on eBay...
  6. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,494
    South Derbyshire
    +203
    I do 50hz via VGA but not to a Panny.
