Thanks ,that is why i have only been able to get a signal with 1080i with my dvi to hdmi,my television only supports 720p at 60hz were as the 1080i supports signals at 50 and 60hz i thought it was down to the v+ box.will ring virgin and tell them not send the tec out know,Thanks for the info
just spoke to virgin and they dont know what it supports 50-60hz, say`s it all dosent it .Are you 100 hundred percent sure badger0-0 that its only 50hz,i dont want to sound ungrateful about the info ,but i need 2 know for sure.
