50hz on a GeForce 6800
Discussion in 'Desktop & Laptop Computers Forum' started by philipb, Oct 18, 2004.
  1. philipb
    philipb
    Mar 6, 2002
    2,083
    63
    Swindon
    +170
    I changed my graphics card over the weekend to a 6800 - used to have a Radeon 9600.
    With the ATI card I was able to use Powerstrip to set a resolution of 1024x768 at 50Hz over DVI into a Pioneer 43MXE1 . Tried to set up the 6800 with the same settings, and I lose the signal (I've tried FRC mode 1 and mode 2).
    Does anybody know if the Nvidia drivers prevent 1024x768 at 50Hz? I'm using the latest drivers.
  2. philipb
    philipb
    Mar 6, 2002
    2,083
    63
    Swindon
    +170
    to answer my own post - apparently 50hz is not available on a Gainward card over DVI.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    :( .. so you're saying individual brands of cards seem to offer different basic parameters to the core chipset they're using? :eek:
  4. philipb
    philipb
    Mar 6, 2002
    2,083
    63
    Swindon
    +170
    hi mate - yes seems so.
    In the release notes for the latest drivers Nvidia say that certain refresh rates are only available over DVI if the TDMS(?) is internal or external. Sorry may have got that wrong - memory not so good these days.
    I could get 50Hz on analogue but it was very ropy - tearing and wobbling.
    So if you need 50Hz on a Geforce, check it out first.
    Actually 60Hz on the 43MXE1 in FRC2 is OK. so not too bothered.
    The info is available on the Nvidia website
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I've seen mention of problems using Powerstrip on 6800s with 'internal' TDMS I think .. whatever TDMS is :rolleyes: .. I believe the dual-DVI boards are 'external', maybe.
  6. philipb
    philipb
    Mar 6, 2002
    2,083
    63
    Swindon
    +170
    Yep that's it. TDMS is the timing chip I think :confused:
    Wish I knew this before I bought it. Actually with the 6800 I can use the Nvidia codecs for postprocessing with Theatertek which give a better result than ffdshow. Maybe not surprising given the TT2 is optimised for GeForce cards.
