50hz 576i or 60hz 480i
Discussion in 'Nintendo Wii-U & 3DS' started by Paul1110, Jan 3, 2007.
  1. Paul1110
    Paul1110
    Nov 24, 2006
    67
    +11
    I have a hdtv Toshiba wlt68 .I haven't got my hands on a component cable yet and as i have cable tv plugged into the 1st scart socket i use my Wii in scart socket 2 at the moment.I looked at my Wii settings last night and it had the setting on 50hz 576i. Could you tell me which i should be playing games on at the moment 50hz 576i or 60hz 480i .
  2. davidcharles
    davidcharles
    Nov 9, 2006
    1,399
    +276
    TBH whichever looks best.....some say 576 as it has better resolution and some say 480 as its 60hz, supposed smoother frame rate...
    i have toshiba 37" and cannot really see the difference between the 2....
    if and when you get component, you will notice a much crisper picture...better text, better colours etc
  3. steggy
    steggy
    Apr 3, 2006
    738
    28
    +46
    Which ever one you think looks best. Try them out with a couple of games and see which one you like.
    Most people lean toward 576i, but it depends on the TV and the viewer.
  4. Paul1110
    Paul1110
    Nov 24, 2006
    67
    +11
    Thanks,i've been so busy i've hardly had time to play it in recent days,i only noticed last night as i connected up to wireless then had a look through all the other settings.I should have more time now to get back to playing Wii sports and then when i get component i'll start playing through Zelda.
