506XDE wall bkt holes
grand
I've ordered the Pio 506XDE and want to put up the wall bracket in readiness for its arrival.
Can anyone advise on the distance between the top of the plasma and the first (top) hole on the unit for the wall bracket?
What's the distance between the 2 holes?
A reply would be much appreciated as the bracket has been gathering dust whilst waiting for the Pio finally to arrive!!
Norbert666
I can check this evening, but I have to say, there is very minimal tollerance. If you are 1mm out, your plasma will be wonky!
p203557
Surely this depends on which wall bracket you are using??? Just don't want someone to be given incorrect information. Grand, if you specify the make and model of the bracket you should get a more accurate reply from someone in the know.
HTH
Richard
grand
HTH
Richard
Thanks for the reply. If I know the dimensions on the plasma, I can work out the correct placement based on the bracket dimensions I have.
The bracket is the Better Bracket tilt plasma bkt.
grand
Norbert 666,
Thanks for your help in advance
