505XDE Help required!!!
Discussion in 'Plasma TVs' started by Niraj, Feb 11, 2005.
  1. Niraj
    Niraj
    Hi All,
    Just got my 505XDE from John Lewis. They've sent me the silver speakers, not the Long Air speakers, but hopefully that will be resolved, am waiting for them to call me back.
    Managed to set it up, and was going through the setup procedure on the screen, and in the first window that came up, where you select the country and language etc, I made a choice in the auto aerial power or soemthing like that and that has led to a message saying that the aerial has short circuited and to check the cable and to plug the AC power back in.
    I've tried that, but that message wont go!!! I recall someone having mentioned something similar a few days ago, but I can't seem to find that thread, so please please please help me!!!
    PLEASE!!!
    Niraj
  2. Moosh
    Moosh
    Sep 12, 2004
    2,002
    2
    Bristol
    +473
    If I remember correctly - switch the Aerial Power to Off. When I first got my screen I set it to On and it shorted (nothing to worry about). I then set it to Off and it tuned in perfectly! :)
  3. Niraj
    Niraj
    Hi Mmahmed,
    Thanks for that. It worked a treat!! :thumbsup: :clap: :hiya:
    Niraj
