505 XDE mounting Issues
Discussion in 'Home Cinema Buying & Building' started by danny daniell, Jan 22, 2005.
  1. danny daniell
    danny daniell
    Jul 25, 2004
    1,403
    +63
    I am now in the process of mounting my 505XDE onto a Vogels wallmount.At the moment the plasma is connected to the wall mount via the six fixing bolts on the back of the screen but it is sitting too low. To gain the extra five inch lift i need i will have to drop the bracket onto the next set of fixings below what i am sitting on now,however,the panel will then only be fixed to the bracket with four bolts instead of six. Is this still strong/safe enough to hold the panel? I cant raise the position of the Vogel mount on the wall as this is situated tight under the sill in a bay window.
    Thanks for your help,
    Dan :)
  2. danny daniell
    danny daniell
    Jul 25, 2004
    1,403
    +63
    What a doofus! :p Just read the manual properly & it clearly states that its o.k to mount on minimum of four bolts. Doh!!
    Dan :D
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,785
    Norwich
    +666
    I hung my panasonic with 2 bolts, my father in law proved that one would be enough to hold the weight by hanging off it, he is 17 stone!!
  4. danny daniell
    danny daniell
    Jul 25, 2004
    1,403
    +63
    Wouldnt like to try it on a stud wall! :laugh:
    Dan
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,785
    Norwich
    +666
    Good point!! :)
  6. danny daniell
    danny daniell
    Jul 25, 2004
    1,403
    +63
    Guy,
    I just got it fired up & it looks o.k,"just" got to wait for it to run in now(100hrs :rolleyes: ) will give you a shout if you still want to come & check it out...probably be a couple of weeks.
    Dan :)
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,785
    Norwich
    +666
    yeah let me know. :)
