Brogan
Has anyone got their 504 set up with 2 conections to input 3 - e.g. HDMI and component?
I currently have my PS2 connected to the component inputs and I have adjusted the settings accordingly - brightness, colour, etc.
I plan to connect my 868 to the HDMI socket (when the cable gets here) and from what I understand, you must manually select the connection to be used on input 3 - i.e. HDMI or component.
My question however is related to the screen settings.
Will these be the same for both the component and HDMI inputs or can you set different values for each?
If you can't then I'm going to have to connect my PS2 another way as it's going to be pain changing all the settings each time.
Anyone with any actual experience of this?
