504 Contrast levels & screen burn fix
Discussion in 'Plasma TVs' started by jfraser, Jan 17, 2004.
  1. jfraser
    jfraser
    It's just taken me the best part of 2 days to get rid of the "BBC America" logo 'etched' onto the top left hand corner of my 504....The logo is a white on black blob that burns with the force of a branding iron. Do these TV companies have any idea the damage their logo's do to high value TV's.....
    FYI I put bugs life on a loop (1.5days), and cranked up the Contrast level....I then put on DVE and left a white screen on the TV for several hours at almost the highest contrast level...(I'm sure it cut some life out of the plasma, but its better than 'perma logo')
    I currently have the contrast set at 42....I have seen some of you guys talk about 26-35.....did you calibrate that, or was it just the lowest level you could live with. I used the blacker than black set-up screen in DVE, and I consistently got the contrast setting of 42-44
