500M Initial Settings - Component
nheather
I've read the sticky on the 500M initial settings for Sky and BluRay and am about to try those out now.
Couple of questions though
1 - Has any seen or got some recommended settings for Component running game (XBox 360 in my case)
2 - My BluRay and SkyHD run off the same HDMI (switched in the Amp). Is there any way to switch between the suggested settings easily from the hand control.
Cheers,
Nigel
YellowSphere
If you're using Pure Mode, the TV will remember different settings for different resolutions and frame rates. So you can set up Sky with one set of settings (as input will be 1080i50) and then Blu-Ray with another (as input will be 1080p24).
kingfats
Hi. :)
I just use Pure mode with lowered contrast to suit :smashin: or you can just use the Game mode and tweak to your preference to be honest.Component quality is quite good on the M.
All the best.
