500 to spend on new base unit *ADVICE*
Discussion in 'Desktop & Laptop Computers Forum' started by Gazza_1862, Jul 5, 2004.
  1. Gazza_1862
    Gazza_1862
    Hi all....I am looking to buy a new base unit and have around 500 pounds to spend. For the last few years I have had pc's built by a local small dealer but they are the type of machines that are chucked together with non discript components inside...I am looking to buy a good branded machine like HP,Compaq or possibly a dell (any good?)...Although I have noticed PC World sell a lot of emachines and the Advent brand,Are these any good as I have been told these are made for PC World using cheaper components.Is it worth while considering one of these "cheaper units?"
    The main two areas I want to consentrate on are very good graphics and good quality sound as I intend to play a lot of games and I also like to listen to MP3 a lot so a good sound card is a must.
    I have also noticed that HP/Compaq now sell a lot of their reconditioned units on ebay under the name of hp_marketplace_uk......has anyone had any dealings with them good or bad?
    Thanks for taking the time to read this and any adice would be appreciated...GAZZA
  2. pinkerton
    pinkerton
    Sep 26, 2002
    416
    Ealing (London)
    +3
    I'm afraid all branded PC's will always cop out on something, ie cheap M/B or GFX. I will always recommend building to spec, you always know your getting quality components. Tell me wot you need and would be happy to "recommend" a spec for you.
  3. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    How about something like this:
    Antec SLK3700AMB case £52
    MSI K7N2-ILSR Delta £76
    Kingmax Turbo 512Mb PC2700 £66
    AMD XP3000+ £94
    Samsung CDRW/DVD £41
    Seagate Barracuda 80Gb 7200rpm ATA £57
    Sapphire ATI Radeon 9800 Pro £158
    Total £544 inc VAT
    The motherboard has 5.1 sound, and something like the 9800 pro video card has a fair price/performance balance and should do you for gaming for a couple of years (forget Half Life 2 etc with all bells & whistles though unless you spend £300 on the video card alone).
    A tenner more on many of the components (CPU, RAM, HDD etc) moves you up a notch, so you could get PC3200 RAM, an XP3200+ and a 120Gb HDD for around £600. If you're into MP3s, a bigger HDD could be a sensible choice, since they're going for silly money these days.
  4. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    take a look on ebay a company called interweb systems are doing very close to the spec recommended for £379
