TreeFiddie
Hi all,
I rent, and my flat has a TV display unit pre-fitted with an IKEA UPPLEVA ORMO Wall bracket for flat screen TV flush mounting - see the mounting here.
A photo of the mounted tv on the display unit, at the distance and angle I view from is below (taken today). The TV currently mounted is 3.5m (~10.5ft) from the edge of the sofa where I'm sat and took the photo from. The diagonal of the total space behind the TV is ~77inches (170*96cm rectangular area) and there's a nice channel routing all the cables out the back.
I've got an LG 43UJ651V on there but it's dying a very early death (assembled 2017 - Poland) due to bad components. A repair bill was quoted at £400 in Dec '20 but unit cost £375; I therefore need to replace it asap. It's physically in A1 condition but now lights up mostly blue (fewer than 20% of the LEDs burn white) so if anyone knows how I can recover some value from it please let me know too.
I've two easy options:
- I can purchase a slightly larger TV up to 50" and mount it beautifully and super easily as per the 43" below
- I can just buy something significantly larger and find a way of hiding the mountings from sight (unscrew & store + make good on the screw holes.. dunno)
Questions:
- Do I stick with the wall mount and restrict myself to 50"?
- If so, which 50" LED TVs do you recommend?
- Not interested in OLED - I think the tech is too new to settle on
- I don't game; I watch broadcast tv (Freeview sometimes) and stream from Amazon, Netflix etc - main content is:
- Action movies, love anything about space (often some dark scenes)
- Live Sport
- Animated movies (Pixar etc)
- Am considering an Apple TV 4K to take advantage of HDR, Dolby Vision and other such nice tricks
- I'll pay more if the build quality means it'll last; medium to high end spend here though long warranties help too
- The biggest light source is a floor-to-ceiling window to the right (you can just about make it out in the blur)
- I hate Android with a passion; I'll avoid it if I can. The Apple TV will make this easier though
- If I decide to just put a TV on its feet and hide the exisiting bracket mounting somehow..
- What do you recommend given the above criteria? Remember I don't want to compromise on build quality too much (though some retailers are offering 6-year warranties out there which makes it easier to sleep at night)
TreeFiddie!
