Hi All,
I've currently got a 2012 Panasonic TX-P50ST50. It has been brilliant (and it still is!) - I'm very much into deep inky blacks on screens, and this delivers in droves (also hence why I have avoided LED panels till now) - however with the dreaded burn-in (I game quite a bit), 5 years later, the whites are looking a bit murky, so I think it might be time...
My expectations are high, but my budget isn't - so as you imagine; I'm willing to compromise on features, and don't mind having previous years models, so as below the key things are:
Budget? I'd like to stay within the £1500 mark - if I can get it under £1000, even better!
Thanks for any suggestions you may have! And remember, keeping the Panny and saving to up my budget IS an option!
- Between 50" and 55" in size (I'm actually limited in space to around 125cm width)
- High IQ, with good blacks, and as little stutter/trailing/artifacts as possible (I'm used to essentially zero visible artifacts with the Panny).
- A low input lag, or a 'gaming mode' that lowers the input lag.
