50-55 inch tv for £400
lucasmidd09
looking for a tv for the lads bedroom only does a bit of xbox/switch gaming nd a bit of normal tv any recommendation was thing of a samsung 50tu8000 for £429 anything better for around this price ta
Dodgexander
Hisense U7Q better in this kind of price range due to the addition of local dimming and higher peak brightness.
Dodgexander
You should consider purchasing at a time when prices are lower in general. I'm sure the U7Q will get a reduction to be in your price range if you buy at a better time.
If its out of reach, they have there cheaper A series if you want a TV using a VA panel. They are just as good as the Samsung you are considering but sell for less. Up to you whether the premium is worth it to get a Samsung. Picture processing and smart TV will be better.
