50” TV Pole Mount Issue
mn92
Hey all,
I need to mount my 50” Samsung to a scaffolding pole (48.3mm diameter) but am having trouble finding a bracket that’s VESA 200x200 and suitable for a 50”.
Is it safe to use a 100x100 VESA pole mount
with adaptors to 200x200 so long as I’m under the weight limit like this?
mikej
VESA 100x100 is a pretty small mount size and more suited to small TVs and monitors. Is your TV definitely under the max weight that bracket will support ? There might be a risk of it sagging to one side if the bracket isn't designed to support such a wide TV.
dbeevers
Does it need to be at the end of the pole or in the middle of a fixed vertical.
There’s several key clamp fittings you could use even a hook to hang it like a picture.
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
