5 m scart
Discussion in 'Cables & Switches' started by jelly, Jan 8, 2004.
  1. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    im after a scart lead to connect my dvd-r to my tv where can i get a DECENT quality lead at 5 meteres from ixos qed sqart which is best???
  2. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
  3. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    is the ixos xht611 any good 40£ 3m
  4. DucatiEVO
    DucatiEVO
    I'm using a 5m Ixos Scart, works great. Think I got it from AudioVisual Online, but can't recall 100%.
  5. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    qed 4100 (p41)£50 superfi rgb only no audio??? any good???
  6. DucatiEVO
    DucatiEVO
    If you buy an RGB only lead then that's all you'll get, no worries if you're not going to be using it on something else in the future.
    I'd say either of the cables from QED/Ixos will be fine, they're both good quality brands.
    I use QED cables a number of times on my kit (just not scart though so can't say what they're like, look nice though) :)
  7. bobbypunk
    bobbypunk
    that is for just 1m on the sqart.
    i'd say the VDH is best but it's meant to be £135 for 1.5m
    so 5m = aaagggghh
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Profigold 5m should cost you around £50-60 depending on plugs and which model, good value for money
  9. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    is the ixos 160 any good £20 from richer sounds
  10. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
