5 connectors voptical?
Discussion in 'AV Receivers & Amplifiers' started by Gadjet, Aug 15, 2001.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    I have a Yamaha A5 and an hitachi 505, with there being 5 individual sockets for phono plugs to go to my amp with 5 sockets would this be a better than just the one connection with my optical connection that i am using now. my reason i am asking this is the thought of 5 sockets carrying info individually to the optical carrying everything with one connector, will using the 5 phono plugs make each noise from each speaker clearer?<br />cheers for any comments
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Stick with the optical connection, this is sufficient for DD, DTS and PCM (CD-Audio).
    Internal decoders of DVD players (which are then using the 5.1 output you describe) are usually of lesser quality than compared to the AV amp/receiver, so it is recommended to use the digital connection (optical or coax).
    Only multichannel DVD-A/SACD must be connected via 5.1 as there is no digital transfer allowed due to copyright issues, hence the decoding must be done in the player.<br />And that's what the 5.1 input on your amp is intended for.
  3. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Cheers Reiner,
    Thanks for the advise and help I will stick to my current set up,
    Phill
