5 channel power amp
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by bjcol, Aug 5, 2002.
  1. bjcol
    bjcol
    Jul 8, 2002
    26
    Bristol
    Can anyone tell me what makes/models are most likely to be available on the second hand market as I'm looking for one. I preferably want to get a one box 5 channel power amp. The only ones I've managed to identify are:
    Myryad T-70
    Sony TA-N9000ES
    I'm not sure what these go for second hand but I want to about £300! Hope thats not made anyone laugh! Someone told me Rotel do one but I don't know the model. The Myryad would suit me down to the groud as it's 40 Watt per channel which will suit my small living room fine. I think the Sony would be out of my price range and I don't really need all that power. If anyone can suggest other cheaper amps and where I should look to find one I'd be most appreciative.
    Ben
  2. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    The cheapest Rotel multi channel power amp is the RB976 which (unusually) has 6 channels, each giving 60 watts - it's a bit over your £300 budget though.
    http://www.avland.co.uk/rotel/rb976/
    An alternative would be to keep an eye out for a 2nd hand Rotel RB985 MKII THX power amp - very nice amps (I use one myself) - new price was £625 so 2nd hand you may find them as low as £350.
    Matt.
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,665
    Manchester suburbs...
    +204
    i have seen the sony one that you mentioned in the manchester branch of sevenoaks. can't remember the exact price, was between £200-300 though, might be worth giving them a call?
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    More power is not always about more volume, but instead better dynamics / increased headroom. Especially the very dynamic sound tracks of movie demand as much power as possible.
    But of course it has to be quality amplification, too.
  5. Guest
    I use a Marantz MM9000 five channel power amp - it's THX certified, but the power output is anywhere from 140 - 170 watts per channel (depending on whether you go by the American Marantz site, the UK one, or the manual!!!).
    It's a decent amp - retail cost is £800, you might be able to get one second hand for half that.
    Hope this helps!
  6. mjn
    mjn
    May 24, 2001
    23,234
    Herts, England
    +11,486
    Rotel make a range of power amps from 2 channel to 6 channel, in a varying price range, check out www.rotel.co.uk
