5/6.1 Receivers and [Rear] Surrounds
Discussion in 'AV Receivers & Amplifiers' started by Jonathan West, Mar 10, 2003.
  1. Jonathan West
    Jonathan West
    Since unfortunately my rear/surround speakers are not equi-distant from my ears :eek: due to usual domestic considerations etc. :confused:, is it reasonable to assume that all 5.1 surround amps allow left and right rear surround levels to be adjusted independently? I know the Marantz SR6300 does allow it, as Marantz are decent enough to allow you to download the manual from their web site ...
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I have only setup Sherwood/Sony/Denon receivers, but all of these did allow you to adjust all channels independently. I would assume that the vast majority, if not all, would also allow this, but there nearly always seems to be an exception to a rule!
    Mark.
  3. Marshan Man
    Marshan Man
    having gone thru the online downloadable manual for the yammy 630... that is also the case that the rear channels can be altered speratly...
  4. Lithian
    Lithian
    Jan 16, 2003
    38
    9
    Edinburgh 3
    My Marantz SR4300 is sitting downstairs and is doing this right now, set the distance in 1foot/0.3metre intervals for all channels.
