5.1Ch Inputs
Discussion in 'AV Receivers & Amplifiers' started by Gerry, Jan 23, 2002.
  1. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    I have a Sony STRDB940 amp which has 5.1ch inputs on the back. Now I know if I get a DVD player that has on board decoding and 5.1ch outputs I can hook up the DVD player to my amp. However what I do not know is what benefits I will get from doing this as opposed to connecting the DVD player to the amp via a digital(opt or coax) cable. Will the end result not be the same.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You don't get any benefit of using the 5.1 connection instead of using optical or coax. In fact it's more likely that the decoder in the amp will outperform the one in the DVD player.
    If you look around you will note that some players have decoder build in and some do not, but you don't have to bother as a digital connection is sufficient to connect to your amp.
    Thus the 5.1 input remains free and can perhaps later be used for a multichannel DVD-A or SACD player.
    Please do not let you put of a purchase just because the player has a decoder build in and you are not going to use it, just ignore that fact and buy if you think the player does fullfill your other requirements.
