5.1 with EX/ES
Discussion in 'AV Receivers & Amplifiers' started by Tim Ingman, Oct 8, 2001.
  1. Tim Ingman
    Tim Ingman
    Nov 2, 2000
    32
    9
    In a DD-EX or DTS-ES setup with additional back speaker (or speakers), when playing “normal” DD or DTS 5.1 material, does the surround output use just the 2 surround (or side) speakers, the 2 rears or the surround and rear units together? ……Or is it an option on some amps? :confused:
  2. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    With Denon you have the following options:
    1. Play nothing,
    2. Play the same signals that are output from SL and SR speakers,
    3. Use the matrix ES/EX decoders anyway to produce unintended surround effects.
    Mark
    [ 08-10-2001: Message edited by: MarkB ]
