5.1 vs 7.1
Discussion in 'AV Receivers & Amplifiers' started by Philly112, Oct 31, 2003.
  1. Philly112
    Philly112
    Oct 17, 2003
    4,179
    Frodsham
    +1,475
    Is it just me, or do most people still use 5.1?? I have a Yamaha AX1 which I may want to upgrade, powering 5 M&K S85'S all round. It seems that all the AV manufacturers seem hell bent on offering more and more channels of amplification, when all I want is 5 channels of good quality power. I want my next purhase to last some time, and therefore to have firewire etc, but the new Yammys and Denons which have this also pack in more channels than I want (as does my exising amp). Anyway, just a comment - will probably have to go for a pre power Bryston or similar, but will have to wait for them to offer the 'new' connections (even the new Arcam power amp is seven bloody channels!)
    Any one else out there paying for amplification they don't need?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I think I'm right in saying that at present there are no 7.1 DVDs and not likely to be any in great numbers anytime soon.
    Real 6.1 .. as opposed to synthesised from 5.1 .. is somewhat more common but still far from being on the majority of DVDs.
    I have yet to see a 6.1 speaker 'set', though maybe I've not been looking carefully enough if they exist they're rare too.
  3. ailean
    ailean
    Just noticed on the Pio ax10i-s you can bi-amp the mains at the cost of loosing the back sur, so 5.1 with bi-amping! Nice! :)
  4. Philly112
    Philly112
    Oct 17, 2003
    4,179
    Frodsham
    +1,475
    Aliean
    Yes, I noticed this too, but my M&K's have only one set of inputs (ie can't be bi wired). Could I still use the Pioneer? Certainly would solve my problems!
  5. mike_cummi
    mike_cummi
    You could use the 2 extra channels to power a set of speakers in another room.
  6. Philly112
    Philly112
    Oct 17, 2003
    4,179
    Frodsham
    +1,475
    My house is already like a spiders web with all the wires. Can't afford the divorce costs if I put more speakers in!
  7. ailean
    ailean
    I think the bi-amping and A or B option on the Pio is a nice idea, you can have 7.1, 5.1 + 2 in another room or 5.1 with bi-amped mains. You might not use it now (it'll still work perfectly as normal 5.1) but later you may either add the extra 2 as rears, need music in a second reception room (without having to buy all the kit) or upgrade you front mains to ones that can be bi-wired.
    To me it's just another tick on the Pio's for my next amp (my ageing Yam A1 doesn't know this yet, Shhhhhhh ;) ).
  8. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    I came up with this idea about 3 years ago. Wish you could patent an idea :D
  9. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Most powers are still only 5 channels, processors are 7.1, just dont use the surround back...
