5.1 surround system on a laptop
Discussion in 'Home Cinema Speakers' started by rvd48, Oct 31, 2004.
  1. rvd48
    rvd48
    i currently have a labtec 2.1 system hooked up to my laptop.
    i would like to get some quality speakers, but i need a external usb sound card.
    i should be getting some money soon, so if i buy this sound card with these 2 eltax speakers and a decent subwoofer and my ****ty 2 labtec speakers.
    would that work ? i.e. can i get the speaker connectors to connect to the usb sound card?
  2. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    Sadly, no.
    For the eltax speakers and subwoofer, you will need an AV amp which you could then plug the sound card into.
    If you want to just use the soundcard, you will need 5.1 computer speakers (creative labs etc.)
    If you go down the AV amp route, you will need 5 new speakers, the current computer ones won't work
    Hope this helps a bit
    Andrew
  3. rvd48
    rvd48
    thanks andrew.
    i think a few months back, my neighbour was wanting to sell his Phillips Home Cinema system, i might buy that off him. although the front left speaker has bust on his system.
