5.1 suggestions
Discussion in 'Home Cinema Speakers' started by Aggress, Dec 30, 2001.
  1. Aggress
    Aggress
    I'm looking to put in a 5.1 speaker setup, but am completely confused about what to go for. i'm not impressed by the satellite jobs and want something a bit more lively, i've got a budget of 4-500 for the lot, can anyone give me a recommendation ?
    thanks in advance
    Rich
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Mission Cinema 7 pack, exceptional 5 speaker package usually £800 now being sold at Richer Sounds for £400. If I had £400 I'd be down there in a flash, and back home quite slowly as I don't have a car and I reckon the boxes would be kind of heavy....
    Anyways, all you'd need then is the sub.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    If you borrowed a supermarket trolley it might make life easier for you.
  4. ali
    ali
    Dec 30, 2001
    14
    London, UK
    Videologic DigiTheatre DTS
    I purchased these over a year ago for £350 and they are pretty amazing. I don't know what satelite speakers you've heard and have been unimpressed with - but give these a shot and let me know what you think.
  5. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Quite sneakily off to Tescos on Wednesday (will be too drunk by the end of tonight to do anything tomorrow), and will nab myself a trolley!
    If I get caught I'm pointing them your way Ian!
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The Mission Cinema7 at 400 is definetely a bargain but listen to it first if it suits you - no point in buying just because it's cheap. I recommend it though, too.
    Alternatively check out Tannoy M(x) series, good budget speakers with some reasonable bass to bridge the gap until you get a subwoofer. There are several models available and with your budget you should be able to get a nice setup if the Mission's don't suit you.
