5.1 speakers etc.. can someone help me with info and good prices....
Discussion in 'Blu-ray & DVD Players & Recorders' started by Maniac618, Jan 9, 2004.
  1. Maniac618
    Maniac618
    Jan 7, 2004
    819
    28
    +25
    Hi, im going to purchase the pioneer 565a dvd player and i'll need some surround speakers to go with it.
    The player has inbuilt decoders, does this mean that i don't need an amp? Im confused.
    Anyway, i'll at least be needing 5.1 speakers and an amp if necessary.
    Please guide me in the direction of some speakers that would be good for rock music and that are not too expensive (£100?).
    Thanks in advance (and sorry for so many threads with questions). :zonked:
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,740
    2
    In a secret location with Jennifer Lawrence
    +9,524
    I think where the DVD has inbuilt decoders it means you still need an amp. It is for connection to an older amp which has 5.1 analog connections but does not have DD or DTS decoding.
    Also the Hifistore have a good range of speaker packages.
    http://www.hifistore.co.uk/category.php?qsCat=AVSPKPACK2
    Greg
  3. Maniac618
    Maniac618
    Jan 7, 2004
    819
    28
    +25
    thanks for the info, i'll check the site out. :smashin:
  4. Maniac618
    Maniac618
    Jan 7, 2004
    819
    28
    +25
    what the hell!!! LOL
    the amps are like £200 and the speakers at least £100.
    Isn't there a decent amp and set of speakers for £100? :confused:
  5. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,740
    2
    +9,524
    Are you after both an amp and a 5 speakers and subwoofer for under £100??
    I would try Richer Sounds in that case. You could probably get a amp for about £60 and maybe speaker package for £60. Can't seen you getting both for £100 though. Unless someone can correct me on that??
    Greg
  6. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +294
    £100's doesn't get you much in the av world I'm afraid. :(
    For that kind of budget you'd be looking at an all in one package that has satellite speakers and a subwoofer that has the amp and decoder in. The 565 is a very good dvd player for the money and spending £100 on an amp and speaker package won't do it justice imo. I'd save a little longer and go the seperates route and buy in bits as funds become available.
    budget amps start at around £100-£150 like this one:-
    http://www.richersounds.com/index.php?f=itemdetl.php&p=301476
    budget speakers range from around £50 to £500 like these:-
    http://www.richersounds.com/index.php?f=itemdetl.php&p=301582
    and
    http://www.richersounds.com/index.php?f=itemdetl.php&p=301719
    and
    http://www.richersounds.com/index.php?f=itemdetl.php&p=205418
    here's an example of an all in one for <£100 (more suited to a pc than home cinema):-
    http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=VDE-ZXR-750&clear=
    and another:-
    http://www.unbeatable.co.uk/CatalogueItem_13491.html
    and:-
    http://www.unbeatable.co.uk/CatalogueItem_12840.html
  7. Maniac618
    Maniac618
    Jan 7, 2004
    819
    28
    +25
    thanks for the links and advice. I'll save for a bit, im going to uni in september though, so it might be a short lived experience with the set up i finally get :(
